I have already done a search on how to install neon lights, but i don't know the best way to hook them up to the battery. Is there some kind of connector i can/need to buy?
Are you talking about interior or exterior neons? Form my interior neons, I actuall took the wire and ran it to a fuse in the fuse box that stays on all the time, then I added a switch to the line. All I did was remove the fuse, split the wire, add one end to the fuse opening and replaced the fuse, and took the other end and used it as a ground by tightening a bolt over it. i know it's kinda ghetto but it works!!!
