1997XLTRollover
- February 28, 2007
- 1996 AWD 5.0
The only way I know of is to degree the cam and see where the cam events are. For a novice (as I am) I think it would be tedious work. I'm betting you could check it by just adding a degree wheel to the front of the harmonic balancer, and pull a valve cover. A spark plug piston stop would be needed to find true tdc also (no idea where you'd find that). Also, you need to know the factory cam timing events. Remember...I'm not the best guy to be giving you advice on this. You really need someone helping you that does this stuff all the time.
Well I do have a degree kit. I've got 2 5.4's I planned on learning to degree, so bought a kit to do those. I would think at least some of that kit would work to use on a 302. Although I have never degreed an engine before.
