- September 16, 2002
- Virginia Beach, Va
- 00 4x4 Mounty
My injectors are brand new, but I suppose that doesn't mean they're good. I've also checked for vacuum leaks and couldn't find any, but again that's not to say there isn't one.
Mine does sit how you described, but from what I've read the position doesn't matter. So long as it's mechanically lined up which mine is because I used the tool, it should be fine. Unless there is something I don't know about. Also when you're saying CPS I'm assuming you mean the cam sync aka distributor?
I had all 7 plugs in the engine during the test and the tester in one cylinder obviously. Remember I have GT40 heads which have bigger chambers, but then again my 99 has GT40P and still runs 130-140 psi. But that weird thing is my 99 runs amazing.
When mine had a bad injector it took me a little bit to figure it out. My symptoms were I would have a solid miss fire after running for about 5 seconds. I ohmed it out and it was right within range, checked signal with noid light and tapped it with a 9v battery with the key on and it would spray and sound just like the others and it didn't leak down. As a shot in the dark I spent $45 on a new one just to see and sure enough it was my issue.
At the time my cylinder was kinda washed with fuel so it had the lowest compression ratio at 125psi (others were 135-160). I though I had a bad rocker arm (mine are aftermarket) but after verifying everything looked good I needed to look somewhere else.
Since I swapped the v8 in my ranger it had always ran great but had just a slight shake at idle. I always thought It might be the tight mounts and exhaust hangers and I was wrong. After fixing the bad injector it runs 3x smoother at idle. It actually idles right at 600 rpm smoothly where it used to sit at 650-700. Now I did disconnect my battery during the process so it had to relearn idle during the restart but I still think the extra leaky injector was the issue of my fuel loss.
Your cam positioning sensor should be installed correctly if you used the tool. I have looked at a ton of used 5.0Ls before and none are in the same place. Hell I have one from a 99 and a 00 in my garage with less than 100k on them and one is straight out and the other is a few degrees to the drivers side. I know if you go towards the drivers side it will run richer or towards the passenger it will run leaner. It doesn't hurt to move it around a little and take it for a drive.
Also what helped in my fuel mileage was to get the speedo correct. Because of the 4406 swap in my truck it was reading 20% fast and shifting funny. I had to order the 23 tooth white gear to slow it down the VSS sensor to get within 2%. Now I can get into O/D at 35mph and the torque converter locks instantly. I have a new 7 tooth main drive with 20 tooth gear to swap in that will get me almost exact.
