1998Exp
- December 5, 2010
- Seattle WA
- 98 Limited V8 AWD
"ECT out of range" does not mean too cold, but producing a voltage that's out of its range of measurement. That usually happens when the sensor is bad, or much more likely, when there is a connection problem: an broken wire, a short to ground, or some such.
The data that you showed in the other post indicates that the ECT is working properly, so it could be just a fluke, or perhaps an intermittent. It's worth pursuing, because the PCM is quite clueless without a valid coolant temperature reading.
Here's some other tests I ran. Might have found an indication as to where my abs issue may be coming from. The ECT out of range I'm assuming is because I ran all these tests before the truck was warm, but maybe not? My ultra gauge reads engine temp no problem but maybe that's reading off a different sensor? It also looks like the ECT sensor is working well based on the real time data in the above post so I think I can ignore that.
