Expl0ring
- September 29, 2008
- Sikeston, Missouri
- '97 Sport
Ok, well i thought i figured out my problem last night, but i dont think i did... i have 12+v at the power and the remote, so they are fine, but last night i couldnt get it to ground to the ground it usually uses(weird) so i accidentaly set the amp on a piece of metal in the back and it turned on (grounded itself?) so i was like ok guess i just need a new ground, so i tried one more time with the same ground today and it didnt work, so before i found a new place i sat the amp on the same piece of metal and blew the fuse (doh) but i dont have any more 25amp fuses right now so i stuck a 10amp in it just to see if it would turn on... but now when i ground it to something or sit it on metal, the triangle light (lit red when on) comes on for about 2 seconds and then goes out... then comes back on for about 2 seconds and then back out.. and so on and so forth.. (i was just holding the ground on metal) so anyways, my question is.. is it doing this because the fuse is to small... or because the ground wasent actually bolted down and i was moving.. or something else????
Thanks for your help guys!!
