- January 26, 2004
- Mechanicsville, Virginia
- 2004 Acura TL
MattHarrell said:Can someone describe for me what the slide pins look like? I don't even see a picture in my Haynes manual
What about anti-rattle clips? Does a 99 have them?
Is the cradle the thing that holds the caliper on the rotor?
1) Slide pins are the things that the bolts go through to bolt the caliper to the cradle. They "slide" back and forth.
2) Most of them have them. If they aren't there when you take your old brakes off, then you probably don't need them for the new ones. Also, if the old clips are there and your new ones didnt' come with them - it's Ok to re-use the clips.
3) Yes, the cradle is what holds the caliper to the rotor!
Hope that helps
-Drew
