DTDK
- May 22, 2011
- minnesota
- 01 sport trac
On my passenger side door you have to lift way up on the handle to open it, the locks work fine and there is tension all the up and down on it so it is not the spring problem detailed above (however my drivers side door needed that and it fixed the issue no problem)
So does anyone know a way to adjust the rod that connects the outer door handle with the latch mechinism? I can feel that there are threads on the bottom of the rod which would lead me to belive that the it can be screwed up or down, but i can not figure out how to get at it to do this.
Thanks
Thanks
