I just got done replacing my passenger handle since one end cracked off at back of handle. I was lucky that my SportTrac is black so the can of Ford Black and Clear coat touch up spray from Advance Auto parts worked perfect. The clear coat leveled itself to a factory finish after laying on good - two clear coats over two black.
I used a smaller nail punch hitting rivet pin from the handle side with multiple 3-6 quick heavy blows. This popped the pin inside the door and the rest is getting those ears broken off on the inside and punching again to the exterior.
Don't forget about letting the window down a little or you'll be fighting to get the handle out.
I used these Stainless screws in the photo below to prevent getting rusted. I ALSO recommend lifting the handle and placing a thin cardboard beneath the edge of the raised handle. This allows you to let it rest on your allen wrench and not get scratched while you're working to get the nut on from the inside. Once the nuts get threaded, a socket and extension (prepared in pocket) will just slip onto the nuts from the slight angle - no swivel needed.
