New gears and the new whine. | Page 2 | Ford Explorer Forums
daaaaaamn. well theres yer problem (redneck accent)
Creager said:
It turns out the pinion seal i bought from Advanced Auto was a total peice of crap. Stay away from 'Motor City' brand seals. That is what was causing my problem with the preload. The inside diameter of the seal (where the dust shield would sit) was just a hair too short. In turn the dush shield on the pinion flange was dragging along the inside of the seal... thus an extra 25in lbs of resistance or drag on the pinion when i was trying to turn it.
It might have not been a problem in the long run to use the seal, it was just throwing my preload off so it was kind of confusing.
I used BCA National's pinion seal, which is made MUCH better. Infact BCA makes a very quality product, i would recommend them over Timken anyday (for their seals of course). Its not the basic green seal (or orange from timken). Their seals are built MUCH thicker, so it doesnt bend or warp during installation. And their seal also comes with a ring of silicone built into it, something i havent seen ANY other brand do. Very cool.
The whining noise is still there... althought not as apparent as it was before. I changed out the U-joints with no luck. I figured that might have been the problem, although it did fix other issues, i didnt fix the actual one i was going for.
So the issue still remains. The gears make noise.
It is possible that its the Tranny i am using. I have no real way to find out for sure. The transmission was put in mabye 3000 miles before the gears.
But also it is known that if a gear set is set up with a PERFECT heal/toe patern in mind (IE Pinion depth) then it could become noisey. Because a perfect heal/toe patteren is usually impractical. Mainly because differential housings are not all machined the same. I changed the pinion depth with my jump from 3.27 to 4.56. With ford rear-ends, you probably dont even have to. (ford uses THICK gears on all their coorperate rear ends...smart)
Also 4.56 is a BIG gear. BIG gears are known to make noise. This is what randy's ring and pinion told me "if it hasent broke by now [almost 10k miles after install], then you did something right... probably too right."
Do you have any idea what part # is the BCA pinion seal? On Rockauto they list two different parts; one costs twice as much.
Im pretty sure its the $24 dollar one.
I dont have the part number, because its pressed into the pinion bore at the momment! haha, i wish they would show a picture of it, i could tell you if thats the one i was talking about or not.
The one im talking about is thicker then the cheaper seal, thick enough to where you cant bend it (easily if at all) with your hands. The other seal you can bend up using your hands. The one i was refering too is 'rounded off' with a ring of silicone around the outter-sealing surface. The cheap one is squarded off. Go to napa and ask to see the differnt types of seals they have. You will see exactly what im talking about once you look at it, there is no mistaking the superior seal.
