robs2002explorer
- January 22, 2012
- 2002 explorer
New guy here. Have a 2002 Explorer with 100K miles. My front windshield washers work, rear one does not. I have a crack in the pump letting water leak out so I need to replace that first. Looks like it just pulls out of the tank and the grommet is what holds it in there? I figure while I have the hoses disconnected, I will use an air compressor to blow thru the rear hose to see if its clogged. I cant tell where this hose goes thru the body? Looks like a common problem on these trucks. I tried the search function but it did not work. I did find a sticky to fix my no heat problem so will tackle that next weekend. Thanks in advance!
Rob
Rob
