New Guy souther Illinois | Ford Explorer Forums
Haugen
Rosewood heights illinois
been watching the site a while, i have a 93 explorer for a toy and an 07 Silverado for a daily driver my X has been on a superlift 6" lift and 3' bodylift, 35"bfgs for about 3 years and i finally decided to do a SAS my 9" is mounted, still needs shock mounts, i have a set of 7" b.c.Bronco coils i moved my buckets up 2.5" extended radius arms, full width 44, a slight problem, everything is attached except for the trac bar, i'd like to keep the mounting bracket as close to the frame as possable to lower the prybar effect on the frame, just as is when i moved and spaced my bucket i barley have room to reach the rear bolt for my steering box. i'd like to know how other members have mounted their trac bars. pics would be appreciated. has anyone used the adjustable early bronco trac bar? just needing a little help with this one. i'm located in rosewood height illinois, about 20 minutes from St.louis Missouri. Also i'm searching for a manual 1354 i had a friend pick one up for me once just to find out it was a 1350 with the slip yoke one the snout of the t/c. so if you know some who knows someone, let me know what they want for it.
