new head unit | Ford Explorer Forums
new head unit
colder152000
new jersey
98 xlt
So, i got a new headunit and it doesnt fit in my 98 explorer's stock radio's hole. i went on crutchfield and am confused with what piece i need. Can some one help me?
Thanks
order one of each of these
!!!!ATTENTION!!!! this will ONLY work if it is a single din radio, it most likely is but if you want me to check for you post the model number and i will
this is the adapter to make the aftermarket radio fit in your stock radio hole
http://www.sonicelectronix.com/item...oogle&utm_medium=organic&utm_campaign=froogle
and this is the wiring harness that will allow you to plug your new headunit into the stock plug so you dont have to cut any wires
For a double din, what did you order? If it's one of those deals with a screen, then you have to alter the opening. If it's just the stereo, you should have no problems... More details please :)
no what you have is the wiring that plugs into the h/u, the one i told you about hooks up to those wires then plugs into the stock radio connector, so you don't have to cut any wires in the vehicle itself
and yes that bracket should work with your head unit
are their any stores like 6th ave that sells these
uhhhhhhhh.... not that i know of, but if your suspicious of the site, dont be, i have made several large purchases there and no problems at all
that wasnt the issue just i wanted to get the installation done today whatever. thanks again man
