TheOSU32
- February 7, 2016
- Vegas
- 97 Ford Explorer 5.0
So I've just gotten my girlfriends 97 Explorer 5.0 up and running after sitting for 2 years, but over the past 2 weeks I've discovered it's got a battery drain. Has been dying frequently and even over a 10 hour period.
Battery is 6 mo. New, just got tested and recharged at AutoZone. So not the issue.
Using multimeter and determined alternator also good.
Used multimeter to perform battery drain test on negative side, this is where things got interesting. Noticed always about a .7 draw immediately, but would quickly kick up to over 1 once the underhood bulb turned on. I unplugged the number 27 fuse to turn off this bulb and then got a reading of .25, still high, but much less then before. I then continued the draw test pulling fuses (all without fuse 27 so the bulb wouldn't kick on) until I pulled fuse 25 (speedometer/GEM module) and it went down to .01 draw. I then plugged back in fuse 27 but not 25 and I still only got a .01 reading, and underhood lamp didn't turn on. So I assume that is where my draw is.
Now here is where I need help, is the draw in 27 and 25 related? Does it even matter since the draw completely went away once only fuse 25 was pulled?
I'm thinking that the draw is from a bad GEM module not the speedometer, and this might also play into fuse 27. And that it needs to be replaced. BUT how can I be sure? Is there a way to test speedometer versus gem? I want to fix this myself and use junkyard parts if possible, however I don't want to go pull a GEM module for the junkyard if it's not the problem.
So I'm looking for some confirmation of my thinking / guidance in this process. All help is appreciated!
