spinnerg
- November 18, 2010
- GJ Colorado
I own a 2005 ford explorer sport trac with 75,000 miles. It runs great. The battery is the type with the green/red eye maintenance free type. Recently the eye turned to red indicating the battery is not charging which stands to reason since it the original battery, a motorcraft battery and is over 5 years old. I meant to get it replaced but had to go on the road and drive it with the lights on and it drained the battery and left me stranded, the battery light symbol was on the entire time and I knew it was going to drain it. At any rate I replaced the battery and away I went, but still thinking it may be the alternator. With the new battery in and idling, the battery light is off (on dash) when I rev it up the light comes on at about 1500-1700 on the Tac. Last night as the truck was idling I removed the positive off the battery, it kept running, soon as I stepped on the gas it killed the engine, again at about 1700. I have also driven it with the headlights on the highway and the charging gauge with start to go down soon and as you drop below about that 1700 mark it begins to charge. My question is; is this a bad alternator and it was just a fluke that it is going bad about the same time as the battery? Will replacing the alternator solve my problem?
Thank you
Thank you
