New problem (the horn) | Ford Explorer Forums
Monty
Montgomery, AL
2000 Explorer Sport
My horn doesn't work. No biggie, just a fuse right? Wrong, all the fuses are fine. No biggie look for problems on the horn, right? Wrong, we can't find the damn thing. I looked all over the front end. Where is the horn on a 2000 sport. Pics if possible would be a big help. Thanks
I did a quick search, couldn't find any pics. Found that you should check the horn relays first. To tell you the truth, I don't really know where either physically is.
Is your cruise control also not working? If so, I suspect your clock spring is bad or maybe a bad contact on the clock spring.
I don't have CC...
Well we looked under a friends sport for reference and found the horn. Got under there and the horn contact was loose....got it all buttoned up and i have a horn. which is good because I had to lay on it a few times when people pulled out in front of me. Thanks for the help...
the horn is under the driverside headlight ...kinda. move the inner fender and you can see it. you unbolt it from the top by where the battery is. hope this helps. it took me forever to find mine.
So i blew my amplifier fuse when i was working on the dual amplifiers. I stole the working one from the horn.. Are the horn and cruise on the same fuse by any chance? I dont have cruise control now (or a horn since i pulled the fuse) and i suspect that...
