Cartman
- August 24, 2001
- Waterloo, Ontario
- '96 Sport
I finally have a design for a single 12" woofer box that I like so I am now opening it up for all thoughts, I still have to double check the numbers but the total volume should be close to 1.25 cu/ft. I want a good mix between SQ and SPL and the sub is going to be a MTX 9512 or a JL audio W7. Box will be 3/4" MDF expect for the front which will be 1" MDF.
The blue things are going to fit around the amps (MTX 6500D and MTX 4244) and cover up all the wiring to give it a clean look.
Onto my questions;
1. It is going to be painted so what colour? - normally i'd want body colour but I have a green exterior and green interior so I don't think more green works. A graphite metallic is what I am thinking about so far.
2. The arched part for the sub will be fiberglass, does it make sense to have a piece of thin metal (10 gauge) formed to fit on the outside then fiberglass the inside to prevent flex. The metal could stay attached or just be used for forming and removed later. I can have this done at work so no cost to me!!
3. The fiberglass itself - I've read that the fleece material is just to add thickness so do I even want to use it or just go with 6-8 layers of cloth. Which cloth is better - the woven or the random fiber.
4. Might want to cut a 10" dia hole in the back of the box and put a peice of plexiglass in with gasketing to show off the magnet when the seats are folded down, good idea or doomed to failure/ too much work.
Thanks
Onto my questions;
Thanks
