Jagercola
- May 23, 2002
- Kingsport, TN
- '99 EB
Amp MA Audio M1686i
Amp Kit Audiobahn 4-Gauge Amp Kit
Speakers (2) MA Audio SY68F $79.99
Head Unit Kenwood KDC-X569 (2003 Model, 3 pre outs)
Sub ???????????????????
Misc (2) RCA 15" Pro Audiobahn Cables
Satellite Kenwood Sirius Tuner and Antenna
(I've got a 99 EB with Mach System currently. )
This is my system so far. Everything is ordered and on its way. The amp was discussed earlier by Heath I believe. It's 4x100 and 2x200 in 4ohms. thezeb.com has it for 300 and it's over 400 everywhere else. I plan mount this amp and the sirius tuner behind the back panel where factory amp and sub amp are located. Then run 4x100 to the synergy door speakers. I'm going to use the existing speaker wire for the doors. Now the question is, what do I do with the 2x200. I could replace the factory 8" sub with a good one and run 1x200 to it. I also have a sealed box of 2 10" subs (Autotek Silver Street Series, not that great). I could then run the existing 1x200 in this box and wire the subs (2 4-ohm voice coils) for a 2ohm load. Is that what you guys would do? or just rip the 8" out and run it all to the two 10's? Also, how hard is it to mount amps behind the panel? Do I need to use an MDF board as a mounting board or is there one back there? Any other suggestions or tips? Thanks -Will
