New tires = low pressure light | Ford Explorer Forums
Staten Island, New York
'99 mountaineer
Yesterday I had a new set of tires put on. They feel great and I drove it about 25 miles with several starts and stops during the night after they were put on. This morning I leave the house and the "low tire pressure" light is on. I checked and all the tires are @ 34-35 psi ( the same I kept the old ones at). Now after a few restarts and 5 miles the light is still on. HELP......Thanks
go back to where you got the tires put on and they should reset your pressures and relearn the sensors and turn off the light. the tires probly just got cold overnight and the pressure dropped alittle.
UPDATE... Rechecked tire pressure. All ranged from 29-32. I aired them all down to about 20-25 psi while the truck was running and then filled them all up to 35 psi. The light went off before I sat back in the truck.
