New Wheel Fitment | Ford Explorer Forums
New Wheel Fitment
Jerry S.
I have a 2 inch lift, Will these fit the sport trac on some 32 11.5 15 tires? Wasn't sure if these would clear the brakes or if the backspacing was ok. The site listed them as a fit for my trac but I wanted to be sure
Part Number: M/T158421
* M/T SideBiter Wheel
* 15x8, 5 on 4.5 Bolt Pattern
* BackSpace 3 5/16 in.
* Max Load= 2000lbs
* Finish = High Gloss Black Finish
* Hubcentric= No
* Offset = -30 mm
I think because the backspacing is so small, the wheel is further toward the street and therefore is unlikely to have an issue with rubbing the brake caliper, am I correct?
They'll clear the calipers and tie rod ends, your good to go.
No problem, when their on post some pictures if you can.
