Hi Everyone!! I am from eastern KY. I have a 88 Ranger and am having some crank but no start issues. Any suggestions which forum would be best to post in?
Welcome to this forum! Do you hear the fuel pump prime when you turn the key to the accessory position? Did you check the fuses, and relays? Did you scan the PCM for trouble codes? Did you see if there is any spark when you crank the engine?
