PAconstable
- January 1, 2014
- Western Pa.
- 1999 Explorer
Hello, guys. New to this forum, but not to backyard mechanics.
I recently bought a '99 Explorer (X code engine, 5r55e tranny) to use for work. It needed work, but have had it quite roadworthy for several months now. I only own Ford trucks. but usually own Jeeps for daily drivers. The Explorer was better suited to my job demands, so now it's mine and I do like it. 280,x.. on the clock. Runs great.
I am having a couple issues with it that I could use some feedback with and would appreciate. I have been doing some research as I usually do with a vehicle that is new to me technically. I'm up against a wall here, though, it seems.
1) Rear wiper inoperative. Motor has been replaced, relays replaced and do click when switch is on in time with position of delay switch. No fuse issues, power shows at fuse both sides. Jumpered all three switches in liftgate with no effect. No obvious wiring damage. Wiper has worked intermittently a few times but now is stopped altogether.
2) Consistent transmission code for torque solenoid either being stuck off or not powered. Have replaced all 6 solenoids with used but certified good and warranted ones from a transmission parts supplier. Red stripe solenoids. No effect and now having slip in first gear which just started after a long road trip. All gears work all along including overdrive. Fluid and filter have been changed with Lucas additive also used.
I understand that the GEM module could possibly be responsible for the wiper issue. Could it be responsible for the transmission issue also as I know it covers a lot of electronic ground in this vehicle? Everything else seems to work just fine.
Is there a way to test the GEM module without having to go to a dealer and pay their labor rates? Also, if I decide to just throw a new used GEM module at it (I know I need the part number as there are several models and I know where it is located), will it be plug & play or does it need programmed?
I'm sure some of this has been asked & answered, but I'd be grateful for the answers here and now so I can get on with what I have to do to get the Explorer right again.
