Newbie with a problem 70 MPH Whine in dash | Ford Explorer Forums
brianstrange
Ma
2008 Limited
Hello Forum! I own a 2008 Explorer limited, and am getting a whine between 70 and 80 MPH. The noise exists both in gear, and neutral, as long as you are traveling between 70 and 80 MPH. When it began, it sounded as if it was coming from the front left side, and was much quieter, almost as if it was outside. I thought it was a wheel bearing, but I was wrong. After replacing it, the sound is still there, and sounds like it coming from the cluster. I hear it in awd, 4wd, drive, overdrive, neutral.... It is speed dependent, and engine RPM has no factor whatsoever. It doesn't sound like a transfer or trans bearing, or axle whine either. It quickly cuts in and out, and reminds me of a loud, noisy speedo cable. Has anyone had a similar problem, any ideas?
It must be tough that even after replacing the wheel bearing, you’re still hearing the noise. Have you considered having a Ford dealer diagnose the concern? I’m not certain if there’s anything I can do to help, but private message me with your VIN, contact info, approximate mileage, and dealer name if that’s an option you would consider.
Cory
Cory, I'm an old Ford Tech, and prefer to work on my own vehicles. This sounded no different than the 100 or so bearing assemblies I replaced in the past, and would have bet it was the issue. I have the old hub as a spare, and I'm sure it will be put to use in time.
Problem Solved
The noise is related to the windshield trim. Over time, mine opened up enough of a gap to allow the wind to produce a distorted whine sound, that is very similar to a wheel bearing. I discovered the sound would change pitch, in sync with the wipers, when placed on high. It would almost go away for breif moments (milliseconds). I taped the molding to the windshield, blocking the wind from getting under it, and the noise is gone. Now I just need to determine if the windshield seal failed, or just the plastic surround/trim.
Again, the noise was present with the car traveling at 70 MPH, under all loads / conditions, even with the car off, and coasting.
I’m really glad to hear you figured it out. Keep us updated with what you find.
Cory
