Newby 2006 Explorer questions | Ford Explorer Forums
Sfd4
Berkeley twp, NJ
2006 Explorer xts
how do you replace the fog light bulb?
How do you program the lock code that is on the drivers side door
The fog lights is replaced from under the car and behind the bumper. The key pad programming should be in your owners manual if you dont have a manual google ford manuals and go to the ford owners site and download one. I believe to program the door keypad you need the master code that is on a security card that came with the vehicle.
Fog lights are just twist and pull behind the housing. The code to your door pad is on the drivers side floor board behind the fuse box. The code is on the fuse box. You will need a mirror or camera to see it.
