newby installing lift kit | Page 2 | Ford Explorer Forums
Now I get to bust on you. You would be right there mike except for the fact that I had no rivets on my radius arms, they were already replaced. Remember now, old man? ;) But yes, we did throw the jack in there before hand, and put a little pressure on just to hold them in place. Also, it amy be easier to remove the radium arms from the brackets and then go ahead and grind the rivets, install drop brackets, ect beacuse we had one hell of a time lining up all the bolt holes for the brackets cause we didnt take the bracket off the arm. It should be easier to just re-align the radius arms. Unless your working on mikes truck and 1 AM in hazletown with everything covered in tranny fluid using the comealong from hell.
You are right. HA If you recall getting my radius arms in took 2 BAD comealongs and much grunting
