No 4Lo | Ford Explorer Forums
No 4Lo
Sentry6
Norton, MA
2015 3.5 Limited
Hi again.. thats for all the help in the past.. got a new problem :). finally got around to replacing my 4x4 shift motor (talking about snow soon) so i installed it no problem... 4hi works perfectly, in N with brake on i press 4Lo and nothing.. doesnt do anything.. any thoughts, perhaps new motor needs to be adjusted?
Thanks
Is your shift motor new or used? Do you hear any relays clicking in the trunk area? Does your speed gauge work (it must register under 3mph to allow the shift into 4L)?
Brand new Motor, spedometer/cruise work fine, not noticing any clicking will have someone push while i check
Are you in 4x4 High when pressing 4x4 low?
Possible the brushes in the shift motor are not lined up properly?
