Dora the X
- August 22, 2013
- Rockport, WA
- 1993 Ford Explorer
I recently purchased a 1993 Explorer. It is the first X I have owned. It seems to be in pretty good shape, but the tranny won't go into OD. I have spent quite a bit of time searching through this forum looking and learning.
I pulled codes using the jumper method. Here's what I got:
KOEO
111 pass
111
-----------1
157 Mass Air Flow signal is/was low or grounded
543 Fuel pump monitor circuit shows no power
157
543
KOER
111
111
Since I know the previous owner did some work on the X, but don't know all of what he did, and the check engine light is not on, I figured these could be old, resolved codes, and deleted them. I then took the X for a short drive, noting the TCC seemed to be working (based on the tapping-the-brake-while-cruising method) and again pulled codes:
KOEO
111
111
------------1
111
111
I tried entering the output state test, but didn't hear any solenoids buzzing/clicking. I just saw the check engine light come on/go off whenever I pressed the accelerator pedal.
I have located a wiring diagram online (AutoZone). From my reading on this forum, and looking at the diagram, I guess the next step is to check to see if:
1. I am getting power (+) at the 3-4 solenoid
2. The PCM is commanding (-) the 3-4 shift
3. If the signal from the PCM (-) is reaching the 3-4 solenoid.
Is this right? Am I on the right track? Anyone have anything to add?
Also, whenever I let off the accelerator while driving, the X seems to coast as if it were in neutral. I have tried downshifting to see if it would drag the engine, but it doesn't. Is this normal for these vehicles?
Thanks for your help.
Zack (Dora is the X)
KOEO
111 pass
111
-----------1
157
543
KOER
111
111
KOEO
111
111
------------1
111
111
