Exproblems
- April 17, 2011
- Orchard Park, N.Y.
- '05 Explorer XLT 4.0L
Hi All,
I just attempted to start my Explorer this morning and it wouldn't start or turn over. All I heard was "one click" coming from the starter each time I turned the key to ignition "on' position. I've checked thru the forum and couldn't find anything specific to my exact problem. Some past posts suggest a PATS and KEY problem. The remote key fob does unlock all the doors as it should. I only have one key for this vehicle. I installed a new battery last week and the vehicle started no problem each day and time until today. The previous battery did also start the engine each time as well, but I did get a "TEST" message one time before changing the battery. I did notice on the Battery dash gauge that when I held the key in the start or on position for approx. 3-5 seconds, the battery gauge needle started to drop towards the low end of the gauge. I put my battery charger on the new battery and the battery meter on the charger shows a full charge. I also tried to start the engine by using the 50 amp booster charge on my battery charger and got the same result, one click and nothing. No warning messages on dash or flashing icons. The dash icons do light up when key is turned to start position and dome lights work and so does the heater fan, radio as well. The anti theft dash light is "blinking" at it's normal speed when the key is not being turned to on position. My Starter is only 1 year old. Battery connections were tight and very clean. I just unhooked the battery negative terminal and will wait 10 minutes or so to see if this clears up the problem. One thing I did notice is that I do not hear the fuel pump turn on when the key is turned to the on position as I usually would. I then pressed the fuel pump reset button and still got the same thing. If anyone has any suggestions or has had this exact same problem, please let me know, Thanks!
Update, no luck with battery unhooked for 10 minutes. Still get the same problem, one click coming from the Starter and no fuel pump turning on.
