no crank | Ford Explorer Forums
no crank
orlandotom
orlando, fl
2002 sport trac
While probing the inside fuse on my 02 sport trac for a hot spot to plug in a cb radio (there must be some of you who remember those:)), it just quit running. Now it won't start or turn over.
All electrical works...lights, turn signals, radio, etc, etc.
In backtracking where I was when it quit, I MAY have been probing #20 fuse which is the PCM.
I have checked all the fuses and they appear to be good. Could I have shorted(?) the PCM and it needs to be rebooted or something like that?
Thanks for your help in advance
hello- i havea 1992 3.0 ranger - engine will rotate but will not start- plugs have been checked - battery connections cleaned etc- stater relay / motor/ solenoid has been changed - seems to want fuel but i have a full tank-- fuel pump replaced- distibutor checked and cleaned - spark plugs wire good - what could be interferring with the ignition?? it did start a few times but later wouldnt start ?? helpif you know something not in the books?thank you
