Darrman
- October 8, 2005
- Waxahachie, TX
- '92 Sport 4x4/2001 Sport
I am installing a 99 rear axle on my 92, everything was going great till it came time to bleed the brakes. The pedal is VERY stiff, the fronts are bleeding like they are supposed to, but the rears are getting NO fluid. I have taken the entire rear brake hose off, just open steel line, and get nothing. Again the pedal stays the same on the rears but the fronts do like they are supposed to. Also the master cylinder is working, pushing fluid out both ports.
My fear is that somehow the prop valve is closed or something. I had the line open for a couple hours while I got the new axle in place, and refilled the master cylinder before the bleeding started.
Any help will be greatly appreciated, thanks!
