no fuel no spark??????????? | Ford Explorer Forums
yellowvdub
waterbury C.T
92 mazda navajo
ok its a 91 mazda navajo i changed all three relays they all work checked fuses... fuel pump does not turn on and i have no spark.... i also swapped out the ecu too
i have a whole other parts car ;)
Did you check the fuel inertia switch under the dash? It is designed to cut off the fuel supply in the event of a roll over, but sometimes they pop for no particular reason.
Also make sure the wire at the bottom of the inertia switch is firmly attached.
Make sure the number's on the ECU match, there were slight differences in the first few model years
Check the rest of the engine management power supply wiring.
Is the fuel pump priming? If so, maybe there's a problem in the CKP/PIP/TACH signal, which are necessary for spark, and the computer won't turn the pump on until it sees the TACH/PIP signal.
