No heat after 160 thermostat install | Ford Explorer Forums
SoCalHarley
Location
Savannah, GA
Savannah, GA
2018 Ford Explorer Sport
I did a Livernois tune, 3 bar, plugs, CAI and exhaust along with 160 thermostat. Car is heating up OK per Aeroforce gauge but almost no heat is blowing, Don't think the thermostat could be the issue but thought I would check with you guys to see if anyone had this issue. Thanks
Welcome to the Forum.:wave:
Looking at what you added/changed, I don't know what else could affect the lack of heat other than the thermostat. Just a guess though. Perhaps a member familiar with tunes could provide more insight.
Thanks Peter. After checking many threads i kept seeing air in the system as a cause. I did burp the system when i did the install initially but apparently there was still air in the system. I did not think this could be the cause but checked the water level and it was down so I did the process again and now all is good. Heater works as it should.
