just yesterday I was driving home from work and I noticed that my temperature gauge was getting higher than it normally does but my heat was just blowing out cold air (it has been very cold the past few days here in Cleveland, Ohio). But anyway it never warmed up by the time i got home. The next morning i came outside and noticed a puddle of antifreeze on the garage floor. So talked to a few friends and we came to the conclusion that it might be the thermostat, so i changed it today but the same problem is still there. I noticed each time I let the truck run for about 5 minutes, it would leak most of the anitfreeze and water I had just put in the radiator only after i shut the truck off. So i tried just pooring water in the radiator with the truck off to see if i could tell where it was leaking out from. The water is coming out just above where the oilpan meets the block IN THE FRONT OF THE ENGINE. Could this be a water pump sealing problem? Bad water pump? Crack in the block? I have no clue as to where the water could be geeting out. Also when it is cold outside the trucks speedometer will read at a much higher speed than what I am really traveling. for example I could be going 30mph and the speedometer will read 50 or 60mph. Please help I got to get to school and work Monday
Thanx BARI
Thanx BARI
