VelociRanger
- July 4, 2021
- Royse City
- 2002 Explorer Eddie Bauer
Just replaced the radiator, thermostat housing with new thermostat, new coolant temp sensor, and new heater control valve. I still have no heat in the truck, and the bottom radiator hose is significantly cooler than the upper hose. On the heater control valve (it’s the 4 port) all 4 ports are hot, so hot I can’t hold them for more than 15 seconds so that leads me to believe the heater core isn’t plugged up, but when switching from ac to heat the valve doesn’t ever move. I tried zip tying the valve open, but still no heat. I looked at the blend door actuator thingy that seems to be the biggest cause and I can see it actuate with no clicking, maybe the gears are entirely stripped who knows. The only thing I can think of is there’s a vacuum leak somewhere and it won’t open the control valve, and the water pump isn’t pumping enough pressure to circulate the coolant everywhere it needs to be. Any help is appreciated, trying to fix fast before the cold weather hits too hard.
