F15E_WSO
- April 24, 2005
- Washington DC area
- 2002 XLT; 2001 Exp Sport
Got a CEL with a P0171 Lean fault, tried the IAC and Mass Air Flow sensor but it persists, others suggested replace the fuel filter so tired that next.
Got the filter and the disconnect packet of plastic rings, could not get the 3/8th ring/clip to release the lines. The plastic removal tool/clip is VERY blunt on the end, not tapered at all to slip in there and release the clips. Is this normal that it is blunt or did I pick up a lame packet of these overpriced plastic rings?
Tried to do this on my back in the driveway; pulled two fuel pump relay fuzes under the hood and the car died both times in about 3-5 seconds so don't know how much fuel "pressure" was released running the car until "fail". Nonetheless not comfortable squeezed under the car with the potential for a fuel deluge so taking this to auto-hobby shop next weekend.
Question is why am I having so much trouble releasing the fuel lines? I saw two or three posts detailing on how to use the release-tool but no luck. Can I anticipate this to be easier standing up under a lift or is there some voodoo involved that I am missing on what would appear to be a simple operation.
