No Oil Pressure, Engine Stalled | Ford Explorer Forums
12secSS
Santa Clarita, Ca
1999 Explorer Sport
On my way home to pick up my wife during my lunch break, my Explorer suddenly felt very low on power. I looked at the gauges and the oil pressure gauge was at the L mark, no oil pressure. The engine stalled and I had AAA tow it to a local me3chanic's shop (he a friend). While I was waiting for the tow truck on the freeway, I tried starting it, it did ... but was making valvetrain noises (lifter tapping), as if were out of oil. I am hoping it is just out of oil. Although I had one of those quick lube places change my oil about 5000 miles ago. I tried changing the oil myself the first time, dumbest design ever, I won't do that again. It spilled all over the place. Anyway, are the 4.0L SOHC engines known for having bad oil pumps? Any ideas what else it could be ... I am hoping not to have a big bill when he calls, I doubt it could be the engine. I was not knocking like rod bearing failure. Thanks for your help!
George P. Lara
1999 Ford Explorer Sport
4.0L SOHC V6
4-speed Auto
2x4
3.73 LSD differential
138K miles
Lifter tapping usually is a sign of no oil getting to them. Why is another question to be seen.
i would put my money on the plastic from the timing chain casetts clogging the oil pump pick up.
that would be my guess 2
it stalled while driving? that all bad... my truck stalled while i was driving it because the piston decided to pop out the side of the block.....
I knew it, I spoke to the shop ... the bearings are shot. :frustrate
