coffeemandave
- March 18, 2011
- Minneapolis, mn
- 94 ranger 4.0 4wd xlt
I have a 94 ranger 4.0 4wd xlt transmission works perfectly except no overdrive and no converter lock up. The cruise control is also inopperative.
here is what I have checked so far.
took to local autoparts store and ran a code scanner-no codes
checked vss signal seems to be perfect gives an ac signal that increases with speed.
I did visually inspect the wiring seems to be intact.
Payed the local ford dealer for diagnosics which came back with nothing. They said that they checked all the sensor and the brake switch.
The ford man said there was no way for him to turn the solenoids on and off on this model to check them. He confirmed that the computer is showing no codes.
I know that this info may be covered in other posts, but when I tried to search I came up with hundreds of posts and I couldn't figure out how to find my problem please Help!
