I just did a head job om my 1992 4.0. After getting it all back together. It ran ok but it has no power. I started look to see if all the cylinder are firing. I started seeing if pulling the plug wires would change the way it runs. When I started to pull the wires on the left side I could not get to the plugs so I started pulling the wires out of the Coil - Ignition . When I pulled the first wire it sparked and I had a fire from gas fumes that seam to be building up around the top of the engine. That was scary!! Got the fire out and the engine still starts and runs.
I am still smelling gas fumes so now I think This might be the case of the lack of power.
What should I check on the upper or lower Intake manifold that would be casing the gas fumes and lack of power
