zfinger
- August 6, 2006
- Poland Maine
- '97 XLT V8
1997 Explorer XLT V8 138k
My front and rear wipers, windows and dome lights dont work. I started by checking for blown fuses. Didnt find any. Then I purchased a new battery saver relay. Didnt fix it. I also swapped the relay into every possible spot in the box above the pedal. Did nothing.
I then tested for power at fuses 23(starter relay/anti-theft) and 27(all accesory lights) and found they arnt getting 12v. When is use a fused jumper wire off fuse 19 (ignition coil) to both fuse 23 and 27 the dome lights come on.
Possible things here: Does fuse 23 only get power when I turn the key to start it or should it have power with the truck running? And does fuse 27 get power while running or does the door pin effect it? Now if either of these circuits were bad wouldnt the fuse in my jumper wire blow? Can I assume all circuits are good?
Some of the relay tabs in the box above the pedal were getting 12v and one at the top wasnt. Is its power supplied right from the GEM module?
Am I down to the GEM module now? Is that all thats left? Are there any wires I can jump power to, to bypass the GEM module and get my windows and wipers back? I had to do this in my 240sx to get my taillights back.
HELP!!!
HELP!!!
