dendo77
- August 23, 2008
- Taunton, MA
- 2000 Explorer Sport
Hey guys I'm looking for a little brainstorming here with my 2000 Explorer / 5R55E problems.
It all started earlier this year with the 2-3 flare. I drove around with it for a while not a big deal.
Later after driving to the coffe shop one morning, when I was leaving, reverse no longer worked as did Drive. So I downshifted to manual 1 and it went ok.. shifted up to manual 2, still good. popped it into drive, slippped bad, so I turned overdrive off, worked fine. At 55 i turn overdrive back on and it's ok. I also had no engine braking in Manual 1 or Manual 2.
So i did some research and purchased a rebuilt Valve body, separator plate with bonded gaskets, filter and made the swap.
After the swap nothing really changed, except for the fact that I now have engine braking in Manual 1 and 2. After driving around and experimenting here's a breakdown.
Manual 1 is good and strong.
Manual 2, also good and strong.
Drive (with overdrive off) 1st is like neutral, though vehicle does try to move slightly, 2, 3, 4 seem to be ok.
Drive (with overdrive on) 1st is like neutral, though vehcle does try to move slightly. 2 and 3 are also no good, but 4 is weak but doable if necessary
Reverse is the same as 1st in drive. I can feel a bump of the tranny wanting to engage, however it barely moves at all, and has high rpm's.
When the transmission has cooled, Manual 1 and 2 make the vehicle "shudder" a bit but only until it warms up ( 2-3 miles)
Like I said, these problems came out of the clear blue. it was driving fine (except for the 2-3 flare) and all of a sudden, no more reverse or low gears in drive no grinding noises, no pops, nothing.. just kaput.
After the VB swap, I cleared the codes then drove it around and after the new codes popped in, I took it to autozone and they gave me 2. one was for lean gas (but could also be a dirty MAF), the other was P0720, which is the OSS sensor on the tranny.
I am going to replace the OSS sensor but I was wondering, where should I look for my other troubles?
From what I've read, I have good reverse/low bands since Manual 1 and 2 work great. I know different solenoids, servos, and bands operate differently when the od is on or off.
I have the ATSG guide so if you're referencing that, could you include the page number so I'll know exactly what you're referring to?
thanks.
thanks.
