no speedometer | Ford Explorer Forums
no speedometer
racefan100
sc
93 explorer
I swaped transmissions on my 93 explorer (4x2 manual) there is no place for the speedometer gear.I understand there are electric sensors on some vehicles.is there a simple fix i dont have the old transmission thanks for the help
What did the replacement trans come out of?
My guess is the trans you got was for a newer vehicle that picked up the speed from the rear axle tone ring/abs sensor.
The 1st gens get their speed from a gear driven cable take off the output shaft of the xfer case, or output shaft of the trans (2wd).
I don't know of a solution to run the factory, mechanical, speedo from something else..
~Mark
Swap in a later model rear axle? Or just use GPS?
