YW84U
- March 10, 2000
- BC
- 1991 XLT
Ok, I'm stumped -
This is the second time the Ex has failed to start in last two weeks- identical symptoms:
After driving, well within operating temps, I will stop somewhere for a minute, get back in, and find that it will not start, and the engine compartment is really hot all way around - pwr dist box, air box, fenderwells, hoses you name it all feel to me to be 'too warm'.... There is no sound from the Fuel Pump charging up ....if I leave it sit for 20+ minutes, away I go - fuel pump starts and everything is alright again. Outside temps around 30 celsius.....
Since March 2002, I replaced the fuel filter, fuel pump, fuel pump relay, both new sets of battery cables, 130 amp alternator, new battery, new starter, crank angle sensor, new thermostat, brand new rad, new neg ground to battery.....and probably other stuff (put in Reflexes earlier today!). I do note that the temp guage was rock steady after the rad, but now goes cold while driving - have yet to figure that one out, but do not know if it's related.
If a fuel pump goes bad, don't they just die and stay dead? The thing is just over one year old (Carter, I think..). Two relay changes have not helped either. I don't have a fuel pressure guage, so I cannot check the rail. Would the FPR failing result in such symptoms?
Or is it because I just put new shocks on
Any help is greatly appreciated!!!!
