No-start/stalls when hot
Bwana Bob
Morris Plains, NJ
92 XLT
I was doing some errands on a hot day last week. After the Ex was parked for maybe 20 minutes, I started it but RPMs dropped off immediately and it stalled. Cranked it some more and gave it the gas and after a few attempts it started and OK. A few miles down the road it lost power RPMs dropped off again an dit stalled. This time I couldn't restart it. For the first time in 23 years and 245,000 miles, I had to have my Ex towed. Next morning at the mech that I deal with it started and ran fine. I checked fuel pressure and it was good. Mechanic drove it several miles and it still runs fine, but we have had a spell of cool weather.
My theory is that something electrical is failing when it gets hot, particularly after being parked with the engine off for a while, when components in the engine compartment get heat soaked.
I did a forum search and what came up was fuel pump relay, coolant temp sensor, and coil pack. Coil pack seems the most likely. It is my understanding that in most cases a sensor failure will not stop the engine from running. There are two items that I know of, other than fuel pump, that will stop the engine: The coil pack, if it's 2/3 dead, or the crankshaft position indicator.
By the way, when the failure occurred I did not see a CEL. Mechanic found no stored codes with the code scanner.
When I get it back I plan to inspect the wiring, do a continuity check on the crank position indicator pickup and the coil pack, then try again on a hot day, or perhaps use a heat gun on those items.
Any help would be appreciated. I want to keep the old girl past her 25th birthday!
Bwana Bob
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
larrydd999
Port Angeles, WA
92 XLT, 94 Limited
Don't forget the computer itself. I had a similar problem with my '86 F150 a few years ago. Fortunately it would start after a few minutes, but the permanent fix was to replace the computer. You might want to look at the threads mentioning the computer, I think there were others with intermittent problems.
Larry, KC7JJ
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
Sounds almost like vapor lock, but surely not on a fuel injected engine.
I know it didn't throw a code, but check the O2 sensor as well. Not sure if your 92 has up and downstream O2's or not. But anyway, i have seen O2's go bad without a code, and cause the running condition you describe.
Also, don't rule out the fuel pressure regulator; runs fine, but then when it gets really hot...
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
I've had an issue always related to it having been driven then stopped for 30-30 minutes.
Start it up and it acts like it doesn't want to start. Then it starts and feels like it's loping.
No smoke, no check engine light. I'll gas it until it clears up. Usually does this on warm days (ie not during winter) but doesn't do it all the time.
FR-425
Used to be a road here.
Phoenix, AZ.
1994 Explorer Limited
I'm smell'n water in the gas due to condensation in the gas tank from weather change or possibly pumped it in at the gas station.
Add some water displacer to the tank and drive it for a bit.
Water in the fuel can also cause vapor lock. Speaking of vapor lock, check that your fuel lines are where they should be in particular the one coming up from the fuel filter. If the bracket has come off it can get right close to the exhaust.
Bwana Bob
Morris Plains, NJ
92 XLT
Thanks, guys,
I'll keep you posted on the troubleshooting progress.
Bob
L Low Idle Speed and Cold Start Stalls Stock 1991 - 1994 Explorers 4
K Hard start cold and almost stalls putting the clutch in for a stop. Stock 1991 - 1994 Explorers 8
A Dying right after start up? Weird issue, totally stumped. Videos Stock 1991 - 1994 Explorers 8
B 93 Explorer won’t start with key Stock 1991 - 1994 Explorers 4
L Low Idle and Stall at Start Stock 1991 - 1994 Explorers 2
N *FIXED Crank no start after replacing crankshaft pulley. Stock 1991 - 1994 Explorers 13
O Cold Start problem Stock 1991 - 1994 Explorers 10
C Remote Start Questions Stock 1991 - 1994 Explorers 4
9 Ran great. Went out to dinner. Won't start ?? Stock 1991 - 1994 Explorers 8
P Cranks no start Stock 1991 - 1994 Explorers 3
K 1993 ranger won't start Stock 1991 - 1994 Explorers 1
T 94 every now and then will turn over and not start Stock 1991 - 1994 Explorers 5
D won't start Stock 1991 - 1994 Explorers 4
W I just bought a 1994 Explorer, and it won't start. Stock 1991 - 1994 Explorers 6
R 93 Explorer Crank, no start Stock 1991 - 1994 Explorers 12
C 1992 Explorer Fuel Pump Staying On, No Start Stock 1991 - 1994 Explorers 0
L 1993 4.0 No Start Stock 1991 - 1994 Explorers 36
J Help! No start, fuel pump constantly running Stock 1991 - 1994 Explorers 3
B My 94 Won't start Stock 1991 - 1994 Explorers 7
C 1992 Explorer XL wont start Stock 1991 - 1994 Explorers 2
C 1994 explorer v6 4.0l XLT new fuel pump, won't start. Security system, ecu? Stock 1991 - 1994 Explorers 2
D 93 Explorer dies and won't start again for minutes after a hard stop or turn Stock 1991 - 1994 Explorers 18
C First hesitation, rough idle, then no start... Stock 1991 - 1994 Explorers 4
A Awful Grinding Sound with No Start Stock 1991 - 1994 Explorers 13
M Start working on it' Stock 1991 - 1994 Explorers 13
D 93 explorer won't start not getting fuel. Need advice please! Stock 1991 - 1994 Explorers 1
E Died will not start back up Stock 1991 - 1994 Explorers 10
L '94 4x4 button on dash does nothing, where to start? Stock 1991 - 1994 Explorers 3
M 93 ex won't start replaced almost all components Stock 1991 - 1994 Explorers 5
N 94 Explorer wont start after changing Crankshaft position sensor Stock 1991 - 1994 Explorers 7
T Stump the chump, round two. Rough start... Stock 1991 - 1994 Explorers 14
mr cribb no power, no start Stock 1991 - 1994 Explorers 22
B 1994 XLT - Wants to die on first start of the day Stock 1991 - 1994 Explorers 2
M 1991 Ranger with 4.0 swap No Start Stock 1991 - 1994 Explorers 34
P crank no cold start Stock 1991 - 1994 Explorers 19
S *FIXED! Thx Number4." Changed clutch on my '94, now the engine won't start. O.o Stock 1991 - 1994 Explorers 9
L Hard cold start bad gas mileage Stock 1991 - 1994 Explorers 20
C 94 no start Stock 1991 - 1994 Explorers 6
K Rough idle on cold start Stock 1991 - 1994 Explorers 17
M Dieseling - bad fuel smell - smoke - fast start Stock 1991 - 1994 Explorers 1
D 94 explorer died ,wont start Stock 1991 - 1994 Explorers 19
D 94' sounding very bad at start, still not so great after Stock 1991 - 1994 Explorers 6
S First start of the day Stock 1991 - 1994 Explorers 7
A turns over but wont start Stock 1991 - 1994 Explorers 3
O Ford Explorer No Start!!! Get only a single "click" Stock 1991 - 1994 Explorers 13
T 1989 Ford Ranger won't start. Stock 1991 - 1994 Explorers 1
ld50 Engine dies, won't start, then starts. Stock 1991 - 1994 Explorers 5
G Engine won't start - fuel supply issue suspected Stock 1991 - 1994 Explorers 5
A Before I start working on it AGAIN... Stock 1991 - 1994 Explorers 1
K No start Stock 1991 - 1994 Explorers 6
Similar threads
