This is in my wife's 2007 Explorer V6. I unhooked the battery cables to clean the posts. When I hooked it back up it started up but there is no throttle response. It's idling at around 550. If I hit the gas it will go up to about 575 to 600.
The check engine light and the wrench light are both on. I checked the codes and got
P2102 - Throttle Actuator Control Motor Circuit Low
p2104 - Throttle Actuator Control System - Forced Idle
After that the pos scanner quit working. It temporarily worked for several more minutes after I gave it a good whack.
Does anyone know what the problem could be?
