A faint "ticking" noise has developed on my 97 AWD V8. Occurs only when cold and on load, acceleration in all gears. Sounds like it is speed sensitive but can't tell if engine RPM or speed of vehicle. Stops when coasting and if shifted into N; even when engine is reved while moving or sitting still. After reading most of "noise" threads, changed air filter (standard one),cleaned MAS and checked all heat shields. Sprayed cleaner into throttle body AND THEN read the sticker that says not to clean because of a coating. Recently has new IAC. Otherwise, great vehicle and nearly no problems at 48,000. Thanks for any help.
PS: Always disappears when warmed up; just 5 minutes or 3 or 4 miles even in the 30 degree days.
[Edited by sqrodgers on 01-21-2001 at 11:19 AM]
