Noise in rear. | Ford Explorer Forums
Noise in rear.
ruzztec
McCreary County,KY
92 XLT 4.0/99 XLT 4.0
Ok so my whole break system was replaced by me because i neglected it for too long. I now have a new noise...like a warped rotor sound and the (P)engaged only makes it louder. However when i make right hand turns the noise stops. I think its a wheel bearing in the rear but am unsure which side....would it be the left? How to i know for sure?
ok update it was not the bearing but the parking break spring at the top of the system. anyone got a pic how this goes back together?
hmm after some research iv found a picture but i have it together properly.....why does the (retraction spring) rub the backside of the axel shaft....right where the stud are. It only does it on passenger side and if i pull the shaft to me then i get just enough clearance to not rub. ???? stumped. Pic comming very very very soon...like in 10 mins soon
ok found the solution. The spring was resting on top of the (p) break leaver...i pushed in under it and it poped into place. All seems well now
Glad you were able to locate the source. Little things like that can be very frustrating to track down. Sorry I didnt see this earlier, or I would have chimed in to lend a hand.
Looks like your good to go now! Good job!
