Mark_ZZ3
- November 25, 2001
- Western Canada
- 1991 XLT 4X4
I have a 1991 Explorer XLT. When in 4x4 HI, at a steady speed, perhaps light throttle, all is good.
On decel, you can hear a growl or whirr sound from the front end.
On Accell you can hear a similar sounds.
I assume this is something either on the hubs or the front gears.
It is common that the front hubs can be heard like this? Or is it a sign they are wearing out? If so, what part is exactly wearing out?
It almost sounds like a ring and pinion noise, like you have the backlash too loose and you get a growl.
I am going to change the front diff fluid becuase it is past due and make sure there is nothing in the fluid.
Anything I can visually check on the hubs to see if they are worn out?
Mark.
Mark.
