1996B4000
- January 25, 2022
- Heathsville VA
- 1996 B4000 LE
This is not exactly a Ranger/Mazda question but I don't know where else to turn.
Ford Explorer, 2004, replaced alternator -- red battery light was on, alternator putting out 7 volts, also battery was 6 years old. Replaced battery also.
Got a NAPA alternator, it went on with no trouble other than fighting the belt tension.
HOWEVER -- the red battery warning light on the dash stays on, indicating no charge getting to the battery. BUT -- with motor running, voltmeter shows 14.2 volts at battery terminals, which I think means that's what the alternator is putting out. Motor off, battery voltage is 12.7.
I double-checked connectors, etc., on alternator, all good. Tightened mounting bolts to ensure good ground. all good.
HOWEVER -- I touched the alternator, it's running hot.
Any suggestions?
THANK YOU.
Any suggestions?
THANK YOU.
