jcactusleo
- August 4, 2012
- Sterling, CO
- 1999 Explorer XLT
Ok, so I know about the 2-3 flare issue, all well and good. My problem however is when I put the shifter from park down into drive, it doesn't go into gear right away. It makes a buzzing noise in D and N and when in D, you can rev the engine high and then it slams into gear. If you go past D, into 2, then back to D the noise goes away and it drives just fine. Sounds like a fluid flow problem?
Took it to a shady (I know, please be nice. I was poor at the time) trans mechanic who said he dropped the pan and could tell immediately it needs a rebuild for some part that leaks in the center of the trans. You guys got anything? Thanks!!
