anthonytony
- August 28, 2004
- KNOXVILLE TENN
- 2000 sport 4X4
Hi...I have a 2000 Ford Explorer 4wd... the O/D light started flashing and the transmission started slipping in 2nd gear only last week. We did a filter change it seemed to correct the problem from last Wednesday till this Monday.. then it all started again. If I manually shift it it works fine and sometimes it will work for a little bit after I manually shift it once of twice then go back to slipping again. Also it doesn't do it constantly... I may go out right now and it won't do it at all, or yet I could leave and it will do it as soon as I pull out, and not do it on the way back, it doesn't seem to matter if it is hot or cold, it just seems to have a mind of its own.. does anybody out there have any suggestions? Or has anyone had this problem if so what was it and about how much am I looking at to get it fixed. I guess I should ask about how long it should take to fix it too.
Thanks for your time. Shannon
