jsfordboy02
- September 15, 2008
- Iowa
- '97 Sport
1996 4.0 sport auto. The "o/d off" light on the dash has been flashing every once in a while. Why?
When mine did that it was a speed sensor. But then again my spedo didnt work or nothing.
If you're asking this question you should probably have a shop do it.Are these seleniods and valve bodies internal or external on the transmission? I can do pretty much anything but I freakin hate transmissions.
Is there only one valve body that this gasket blows out of, or is there more than one to check?from what I have heard, when the trans starts to have some problems it shifts into a "limp home mode " that jacks up the line pressure so you can still get home when on the road. The light flashes to tell you about the problem. this is why sometimes you may experiance hard / abnormal shifts.
I think I read somewhere that usually the valve body gasket blows out causing a drop in pressure, I think I also read that it will only allow you to start the car 12 times in "limp mode " to protect the trans, but if you disconnect the battery it clears the code and gives you another 12 starts, But don't quote me on it cause it's been a long time.
Any trans shop should be able to read the code and tell you what the problem is...
